SSL VPN client error ...
I tried to setup a VPN SSL Client on ASA 5520 as stated in the link below:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008071c428.shtml
WebVPN works fine but the SSL VPN client refuses to install with the error: "The ssl vpn http response code received from the gateway indicates an error, contact your network administrator"
My environment:
- Cisco ASA 5520 v. 7.2(2)19,
- ASDM v. 5.2(2)
- SVC client: sslclient-win-1.1.4.179.pkg
- Desktop: Win XP
Note: I have only the sslclient-win-1.1.4.179.pkg, not the .zip file do I cannot install directly the client.
Please advise
Overall Rating: 5 (1 ratings)
Farrukh Haroon Tue, 06/03/2008 - 06:43
  • Red, 2250 points or more
Hello,Can you post the output of
debug webvpn tunnel
debug webvpn authentication
debug webvpn aaa
Farrukh
I do not have these debug options, this is what i have:
asa1# debug webvpn ?
<1-255>
chunk webvpn chunk debugging
cifs webvpn cifs debugging
citrix webvpn citrix debugging
failover webvpn failover debugging
html webvpn html debugging
javascript webvpn javascript debugging
request webvpn request debugging
response webvpn response debugging
svc webvpn svc debugging
transformation webvpn transformation debugging
url webvpn url debugging
util webvpn util debugging
xml webvpn xml debugging
asa1#
Farrukh Haroon Tue, 06/03/2008 - 08:27
sorry those are the options for the IOS SSL VPN implementation, try the following:
debug webvpn request
debug webvpn response
debug webvpn svc
Farrukh
Farrukh Haroon Wed, 06/04/2008 - 03:49
Its great that your problem is solved now. And thanks for sharing the debugs even after the problem was solved, for the benefit of all readers.
Farrukh
