how too ??
Jun 3rd, 2008
hi,
i have about 400 ap`s some with CDP some without, how can i apply the CDP setting to all AP`s via my WCS withouh overwriting the individual settings for each ap on antenna,channel,name,power etc..
i.e just activate that setting globally on all AP`s from WCS.
any help ?
cheers
Megz
Scott Fella Tue, 06/03/2008 - 13:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You should be able to create an access point template and just enable that feature and apply it to the ap's. All other settings will not change.
meggerman Wed, 06/04/2008 - 00:20
thanks m8,
yes i had worked it out already.. i only applied CDP enabled on the tablet and applied to one controller.. the result was power and channel settings went back to auto ? but CDP was enabled.
strangley even though i have checked my WCS and WLAN for CDP settings and they have all been applied correctly.. i still get a WCS 'false' WLAN 'true' on my audit report next to CDP settings ?
any ideas ?
Scott Fella Wed, 06/04/2008 - 02:34
  • Hall of Fame,
    2017 Wireless
Is cdp enabled on all th eswitchports?
meggerman Wed, 06/04/2008 - 03:37
have checked, it is.
so im just wondering how my WCS has a different configuration from the wlan controllers :(
Trending Topics - Security & Network
