vpn tunnel
Jun 3rd, 2008
hi , i have a VPN tunnel up but is not passing data traffic, i have also voice traffic that is ok
voice seg: 192.168.2.X
DATA SEG : 192.168.1.X
thanks
access-list outside_cryptomap permit ip 192.168.2.0 255.255.255.0 192.168.20.0 255.255.255.0
local ident (addr/mask/prot/port): (192.168.2.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.20.0/255.255.255.0/0/0)
current_peer: 192.168.101.3
#pkts encaps: 512, #pkts encrypt: 512, #pkts digest: 512
#pkts decaps: 1081, #pkts decrypt: 1081, #pkts verify: 1081
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 512, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#send errors: 0, #recv errors: 0
local crypto endpt.: 192.168.11.3, remote crypto endpt.: 192.168.101.3
path mtu 1500, ipsec overhead 58, media mtu 1500
current outbound spi: AD04B746
inbound esp sas:
spi: 0x0209C6ED (34195181)
transform: esp-3des esp-sha-hmac none
in use settings ={L2L, Tunnel, }
slot: 0, conn_id: 1, crypto-map: outside_map1
sa timing: remaining key lifetime (kB/sec): (3824948/28200)
IV size: 8 bytes
replay detection support: Y
outbound esp sas:
spi: 0xAD04B746 (2902767430)
sa timing: remaining key lifetime (kB/sec): (3824917/28200)
IV size: 8 bytes
Crypto map tag: outside_map1, seq num: 20, local addr: 192.168.11.3
access-list outside_cryptomap permit ip any 192.168.10.0 255.255.255.0
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (192.168.10.0/255.255.255.0/0/0)
#pkts encaps: 19, #pkts encrypt: 19, #pkts digest: 19
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts not compressed: 19, #pkts comp failed: 0, #pkts decomp failed: 0
michael.leblanc Tue, 06/03/2008 - 06:30
  • Silver, 250 points or more
The following output suggests to me that your crypto ACLs may not be "exactly" mirrored.
Note: the asymmetry between encaps and decaps.
I would:
1. Look for asymmetrical ACLs.
2. Refrain from using the "any" keyword in crypto ACLs. Modify existing ACLs to specify the specific addresses needing crypto treatment.
Note: I have read many Cisco documents that caution against the use of the keyword "any" in crypto ACLs.
Presumably, you are using the following ACE to match "data" traffic from 192.168.1.X, and that the destination is 192.168.10.0, and not 192.168.20.0 (per the other ACE):
Consider changing it to:
access-list outside_cryptomap permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0
... and the far side ACE to:
access-list outside_cryptomap permit ip 192.168.10.0 255.255.255.0 192.168.1.0 255.255.255.0
The crypto ACLs on the tunnel endpoints must be "exact" mirrors of each other.
singhsaju Thu, 06/05/2008 - 09:46
If you are seeing encrypts but no decrypts then its quite possible that there is routing issue at remote site.
Check routing at remote side for the traffic that is not passing.
singhsaju Thu, 06/05/2008 - 10:09
check routing for 192.168.10.0 network at remote site . The route for 192.168.10.0 network should point back to the tunnel.
singhsaju Thu, 06/05/2008 - 10:56
Sorry my mistake i mean't network 192.168.1.0 not 192.168.10.0.
mehdiidrissi Fri, 06/06/2008 - 01:28
hi ,
thanks for your help , i find the orign of problem ,
i have a routing mistack in my Switch in the remote site (192.168.10.0 )does not point to the correct @ of PIx
