Unity Connection 2.1 fails on HP DL320 G5P Server
Jun 3rd, 2008
We are trying to install the Unity connection 2.1 on the HP DL 320 G5 P server. The server
was booted through DVD and it loads the Unified Communications installation program. The
sequence of the install as below:
• Language selection
• Keyboard Language
• Installation method - for which we have chosen Local CDROM.
After which it fails with an error.
• No Driver Found
Unable to find any devices of the type needed for this installation type. We have tried
sele cting all the listed drivers by the installation ,but in vain.
The details of our server hardware is below. The server was ordered through HP and it is
there in the list of Unity connection supported platfrom list as well.
• HP ProLiant DL320 G5p /Dual-Core Intel® Xeon® processor 3075 (2.66GHz, 4MB L2 cache, 65
Watts, 1333MHz FSB)/4MB L2 Cache/Intel 3210 chipset /1 GB ECC PC2-6400 Unbuffered DDR2
SDRAM Memory/ Embedded NC326i Dual Port Gigabit Server Adapter/ Intel® 82801IR Integrated
Serial ATA Host Controller - 1No
• HP 160GB SATA 7.2K Hot Plug 3.5" HDD for 320G5 - 1 No
• DL320G5p DVD-ROM Drive -1 No
Please advise.
Raj
Overall Rating: 5 (1 ratings)
hubemark Tue, 08/12/2008 - 00:36
Hi Ray,
have you found a solution for this problem?
I `m facing exactly the same problem.
rseiler Wed, 10/01/2008 - 18:01
  • Silver, 250 points or more
You have 2 drives installed? Unity Connection requires 2 hard drives.
Also, according to the Cisco docs, the DL320 G5 server that is supported requires the 'Intel Dual-Core Xeon 3050 2.13 GHz processor with an 1066-MHz front side bus (FSB) and 2 MB of Layer 2 cache', see the following URL:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/product_data_sheet0900aecd80372879.html
rajasekarvs Thu, 10/02/2008 - 04:22
We were told by Cisco TAC that the HP DL-350-G5 is supported for the Unity install ,but not HP DL-350-G5-P is not nupported.
Raj
francesco.casaroli Tue, 04/14/2009 - 09:00
I have the same identical problem with Unity Connection 7.0(2) and MCS7825-H4, this server is an HP DL-320-G5P.
I'll try to transfer to the server via ftp
