anybody know how to create a "pop-up" banner on 2800 vpn?
Jun 3rd, 2008
we use a 2800 with VPN using the cisco VPN clients. Does anybody know how to have a security banner popup when a client connects the VPN?
attrgautam Tue, 06/03/2008 - 06:33
this can be done on the end client pc which connects using the vpn client. In the VPN client options-> application launcher tab, there is an option to run an application when the client is connected.You can probably run some script on the PC which will through up a banner...
Hope this helps
babogar123 Tue, 06/03/2008 - 07:32
Thanks very much for the link. I have tried exactly what is in the doc but it just changes the banner motd and doesn't create any "pop-up" for the VPN client...any ideas?
Farrukh Haroon Tue, 06/03/2008 - 08:29
I tried it on the VPN concentrator, it worked fine for me, never tried the IOS option tough.
I'll update you if I get something useful on this.
