Active Directory authentication
angfeglandagan
Just curious having this kind of setup..Two leg proxy...using the ;
P1 - internal IP
P2 - external IP
What should be the route on both interfaces..
Im using AD not LDAP for authenticating client to have access to the internet.
What do i use... NTLMSSP?
Is there someone out there who has this kind of setup?
khoanguy
The route for internal traffic P1 should be default gateway for internal clients.
The route for external traffic P2 should have default gateway to get out to Internet.
P1 and P2 should be on different subnets.
NTLMSSP for SSO (single sign on), which would be ideal since clients would not be prompted for authentications.
There are some setups using P1 and P2.
angfeglandagan
One quick question, is NTLMSSP supported on Windows 2003 AD? for SSO?
Im tryin to search for any guides on the NTLMSSP under Windows 2003 environment.
regards,
kira
Doc_ironport
Yes, it works fine under Windows 2003 AD, and gives full Single Sign-on (completely transparent to the user as long as they are logged into the domain).
khoanguy
more on ntlmssp can be found here:
http://tinyurl.com/2n2ykh
