CUPC Features
Jun 3rd, 2008
Couple of client driven requests for CUPC.
- Can you see call forwarding information for a particular phone?
- Any visibility into the Park environment within CUCM?
Mark Knepper
INX
Tommer Catlin Tue, 06/03/2008 - 08:49
  • Green, 3000 points or more
I do not believe either can be "seen" from the CUPC icons. If the person searchs in LDAP for another subscriber of CUPC, the CUPS will give out line status. (on/off hook) or if the person is logged in, logged out. In a meeting, available, etc. But I do not recall seeing in CUPC if cfwd is visible from the client side.
For PARK, Im not quite sure. The CUPC will work exactly like an IP phone. So it can Park a call, pickup a call, etc. There are no visuals of what calls are parked, etc if that is what you mean
mknepper Tue, 06/03/2008 - 09:30
That it is similar to my experience around CFWD.
With Park we are running into the need for people to "follow up" to make sure PARKed calls have been retrieved. The ability within Attendant Console to view the "parking lot" is currently used heavily for this purpose, as well as if a user forgets where they parked the caller.
Mark
Tommer Catlin Tue, 06/03/2008 - 09:38
I think there is a trigger for Parked calls to ring the person back. I could be wrong, but I would have to look up the parameter in CUCM.
There is no visual the end user on what calls are parked and where. You would need some sort of console for this or Contact center application to see which calls are in que
