Call forward with possibility of routing back to original called party's VM
Answered Question
Jun 3rd, 2008
I need to configure system to allow call to extention 7111 forwarded to 7222 in case 7111 doesn't answer. And if 7222 also doesn't answer the call should get forwarded to VM of 7111 i.e. original called party.
Any help is highly appreciated.
thanks,
inner_silence
Correct Answer by Rob Huffman about 9 years 1 month ago
Hi Inner Silence,
You can fix this for CUE;
Mailbox selection
This configurable option specifies the mailbox to be used in case of call forward.
From this doc;
Cisco Unity Express
Release Notes for Cisco Unity Express 2.3
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_note09186a0080679b50.html
Mailbox selection: Mailbox in which an incoming voice message is stored. The options are original called number (OCN) or the last redirected number (LRD). LRD is the default option. You would need to change this to OCN and you would be good to go :)
From this doc;
Cisco Unity Express 2.3 GUI Administrator Guide
http://www.cisco.com/univercd/cc/td/doc/product/voice/unityexp/rel2_3/cue_cli/ch3sys.htm#wp1075610
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Tommer Catlin Tue, 06/03/2008 - 08:53
  • Green, 3000 points or more
I would probably do this in Unity instead.
Setup like this:
If outside caller hits 7111, rings 4 times and goes to Unity.
Unity picksup the call forward no answer from 7111 and plays 7111 greeting
Greeting can say: "Hi, you have reached Joe, Im not available, but if you like immediate assistance, press 4 now or leave message"
4 will be a supervised transfer. If 7222 does not pickup the call, Unity is "supervising" the call and will "pull it back" to the greeting of 7111 if no one answers.
Also, is it possible that 7111 and 7222 share the same Unity mailbox? You can have 7111 as the primary extension and 7222 as the alternate number in the same profile. In CUCM, ring no answer goes to 7222, rings no answers and goes to the same voicemail box.
questions? hope this helps!
Rob Huffman Tue, 06/03/2008 - 09:16
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Inner Silence,
I like Tommers idea here (+5 points for your innovative thinking Tommer :)
Just thought that I would add that your original thought will work by default on most VM Systems (Unity included). Because Unity (up until Unity 5.0) looks at the "Originally Dialed number" when looking for the mailbox, you can have this setup.
7111 Forward No Answer to 7222
7222 Forward No Answer to xxxx (Unity Pilot#)
When the call flows through 7111 to 7222 and then to Unity on "No Answer's" Unity will revert to 7111's mailbox :)
Hope this helps!
Rob
Kapil Atrish Tue, 06/03/2008 - 12:22
Hi Rob,
My understanding was also same but its not working that way. The call gets forwarded to VM of 7222.
thanks,
inner_silence
Kapil Atrish Tue, 06/03/2008 - 12:25
Thanks for the innovative idea but that's not the solution I am looking at. I want to it transparent to calling party.
Secondly, sharing VM box also is not desirable.
Need some more thoughts I believe
inner_silence
jbarcena Tue, 06/03/2008 - 09:33
  • Red, 2250 points or more
Are you using CCM server or CME? Which version?
What are you using as your VoiceMail system Unity server, Unity Connection, or CUE? Also include the version.
Kapil Atrish Tue, 06/03/2008 - 12:21
I am using CCM 5.1 with unity express 2.3.
inner_silence
Correct Answer
Rob Huffman Tue, 06/03/2008 - 12:31
  • Hall of Fame,
    Founding Member
Hi Inner Silence,
Mailbox selection
From this doc;
Cisco Unity Express
From this doc;
Hope this helps!
Rob
Kapil Atrish Tue, 06/03/2008 - 12:54
I am going to have a look at Rob's doc. Meanwhile i got hold of another setup having CCM 5.1 with Unity 4.2 and the default behaviour is working correctly there. Call goes to VM of 7111.
But yes for Unity connection it seems OCN needs to be set.
I'll test and update.
inner_silence
Rob Huffman Wed, 06/04/2008 - 10:30
  • Hall of Fame,
    Founding Member
Hi Inner Silence,
Here is a "high fiver" to you too my friend!
Cheers!
Rob
