DFM 2.0.11 (LMS2.6) E-Mail Notification Subscription
Jun 3rd, 2008
Where i can see does dfm send email alerts because i noticed that after switch reboot i dont get anymore email alarms. E-Mail Notification Subscription is okay and switch belongs suitable notification group. I havent change anything. Email alarm just stopped to work. Is there any log where i can see does email subscription work. When i e.g boot switch i can see event in Alerts and Activities window but email dont appear. I have done boot for several switch and it looks like problem is in DFM email alarm section because emails dont appear. I have also boot LMS server.
any idea
Joe Clarke Tue, 06/03/2008 - 08:59
Do the alerts appear in the Alerts and Activities Display? If not, then that is a deeper problem. If they are showing up in AAD, then you can enable Notification Services debugging under DFM > Configuration > Other Configurations > Logging, then look at the nos.log for errors.
u346874_2 Tue, 06/03/2008 - 09:07
Yes alerts appear in Alerts and Activities Display. I will try that debugging and try to find errors. thanks
