I need improve my ip sla icmp based for backup
Answered Question
Jun 3rd, 2008
Hi all,
I use ip sla for backup routes with this example config:
ip sla 1
icmp-echo 33.33.3.3 source-ip 88.88.8.8
timeout 3000
threshold 3
frequency 10
ip sla schedule 1 life forever start-time now
track 123 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 ATM0.1 track 123
ip route 0.0.0.0 0.0.0.0 FastEthernet0 22.22.22.1 200
then when ping to 33.33.3.3 fail, the first route disappear and second one through FastEthernet0 is my default gateway.
This happend with the first failed packet but i would like that happend after 3 failed pings.
Somebody can help me?
Regards!
Correct Answer by Joe Clarke about 8 years 9 months ago
You can add the following under your track:
delay down 30
This will delay setting the track object to down for 30 seconds. If, after 30 seconds, it's still down, then the track will go down, and your route will disappear.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 06/03/2008 - 09:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
delay down 30
