ACE Web application Firewall Management and licensing
Jun 3rd, 2008
I have to prepare a design of an ACE Web Firewall solution. I am just wondering about those issues :
- Cisco says that the typical implementation is to put the ACE web firewall into a DMZ of the network. Should the switch used in our network be an ACE App switch or we can just use a Catalyst switch (without ACE module)
- For the management should I use a dedicated appliance for the administration and the configuration of the ACE or I can just use CLI or Web access
- What are the licensing consideration for such solution
