restrictions table for notifcations Unity
Jun 3rd, 2008
  • Green, 3000 points or more
Does anyone know if the restrictions table applies to the notifications per subscriber?
Im trying to restrict notifications externally (9??????, etc) but it does not seem to work.
thanks!
Rob Huffman Tue, 06/03/2008 - 09:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi TCAT,
Message Notification, via the COS and Restriction Tables related to this COS.
Have a look;
***Sending message notifications.
Each class of service specifies for its members a restriction table for call transfers, ***one for message notification, and one for fax deliveries. The restriction table can be the same for all three, or different for each. Note, however, that the AMIS restriction table is not associated with a class of service; there is only one systemwide Restriction Table that controls AMIS message delivery.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_administration_guide_chapter09186a0080449cbb.html
Select a restriction table for each of the following:
**Outcalling:
Select a restriction table to limit phone numbers that subscribers assigned to this COS can enter in message delivery settings. The table you select also restricts the subscriber extensions that Cisco Unity dials when the phone is selected as the recording and playback device for the Media Master.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_administration_guide_chapter09186a0080449c55.html#wp1053894
Hope this helps!
Rob
Tommer Catlin Tue, 06/03/2008 - 09:42
Thanks Roberto!
Yeah, I have the subscriber set with a COS that is using the default restriction tables. In the default restriction table for Outbound dialing and have NO for everything and it still dials out.
Im going to create a new table and see if that fixes it. A little odd I would say!
It's 5.01.
cheers!
