CE 566 issue after putting outgoing origin-server
Jun 3rd, 2008
  • Bronze, 100 points or more
Dear Experts ,
I have one CE 566 for my internal users . Previously we were putting ISP parent proxy , but they told us that that proxy will not be no more and you have to put the traffic to go diarectly.
I did the config, but the browsinbg is not working without outgoing proxy . Is there is anything mess up with my config ? Please help
sh run
! ACNS version 5.2.3
device mode content-engine
hostname CE-566-Proxy2-1
http serve-ims text 98 binary 98
http dns-cache size 4096
http append x-forwarded-for-header
http cache-authenticated basic
http cache-authenticated ntlm
http cache-cookies
http client-no-cache-request ignore
http cache-on-abort enable
http cache-on-abort max-threshold 5000
http proxy incoming 80
http proxy outgoing origin-server
hhttp l4-switch enable
http cache-vary-user-agent enable
http smart-range enable
http destination-port allow 90
ftp proxy incoming 80
ip domain-name test.com
gui-server secure port 8080
https proxy incoming 80
interface GigabitEthernet 1/0
ip address 172.16.5.7 255.255.255.0
exit
interface GigabitEthernet 2/0
shutdown
exit
ip default-gateway 172.16.5.1
no auto-register enable
ip name-server 172.17.4.13
websense-server service policy remote host 172.17.0.121
username admin password 1 *****
username admin privilege 15
url-filter http websense server 172.17.0.121
url-filter http websense enable
! End of ACNS configuration
CE-566-Proxy2-1#
dstolt Tue, 06/03/2008 - 16:46
  • Cisco Employee,
Haris,
Are your websense servers working correctly? "http proxy outgoing origin-server" is used as a fail-over mechanism if the rest of your outgoing proxies fail. I don't see any other proxies configured, so I don't see anything that would direct your outgoing traffic other then the default gateway. Is there another device intercepting the traffic?
You may want to consider looking at a newer version of ACNS, however I can't make a recommendation on the code version, and if it's working OK, you may want to stick with what you have.
Dan
