06-03-2008 10:03 AM - edited 07-03-2021 03:58 PM
I have an AP1232 that allows clients to associate - no issue, but the clients cannot do not receive an IP address from my MS DHCP server. There are plenty of IP's available in the scope, and 'wired' clients receive IP addresses with no problem.
Solved! Go to Solution.
06-03-2008 06:01 PM
Thanks for posting the solution!
Please throw a Red Check on it so people can identify it as a solution.
Good Luck
Scott
06-03-2008 11:47 AM
Are the wireless clients on the same subnet (and in the same DHCP scope) as the wired clients?
Do you have any other subnets / SSIDs on the AP?
Let us know
Scott
06-03-2008 12:02 PM
The AP and DHCP scope are on the same subnet as the wired. No VLAN's - flat network.
***This issue was solved by TAC: switch port that the AP was connected too had port security enabled. Needed to be disabled.
06-03-2008 06:01 PM
Good Luck
Scott
