VOIP using a Cisco 2900 switch with 24 ports
Jun 3rd, 2008
Can I use a Cisco 2900 Switch in my VOIP lab. I would like to connect a iphone 7960 to it?
Farrukh Haroon Thu, 06/05/2008 - 11:23
If you switch model supports Power Over Ethernet (POE) you can connect the phone directly to the switch (and it will get power). If it does not, you need a power adapter for the IP phone.
Let me know if you need any help with the port configuration itself.
