Lan to Lan routing help needed
Jun 3rd, 2008
I am trying to set up a Lan to Lan connection for home users to connect back to the main office. I am using a ASA 5505 for the home and connecting back to a 3005 concentrator.
I have the tunnel built and working. When interesting traffic orginates at the remote client, the tunnel is built correctly.
My issue is that I cannot get the routing to update on both sides.
I have enabled RIP on both sides and set the 3005 to use network autodiscovery to update the routing table on both networks.
I either dont have the RIP configured correctly, or I need to enable the NAT rules, but its not making sense to me.
Any help?
Eliufoo.Mahinda Wed, 06/04/2008 - 00:09
Add the following line under the crypto map mode
reverse-route remote-peer
Elly
