Can I take a Cisco 851w and create a DMZ Host?
Jun 3rd, 2008
I have not been able to figure out how to make this possible.
Paolo Bevilacqua Tue, 06/03/2008 - 12:29
Hi, you cannot create a real DMZ lan as the 851 does not supports more than 1 VLAN.
However with the "ip nat source inside" commands you can forward port ranges to a PC, that often is sane things as "DMZ host".
cauley.shane Tue, 06/03/2008 - 15:45
excuse my ignorance, but I thought you could only do single ports with that command. Do yo have a short config example by chance?
Thanks in advance.
cauley.shane Tue, 06/03/2008 - 16:11
Got it below~
ip nat pool p2p 192.168.1.10 192.168.1.10 netmask 255.255.255.0 type rotary
ip nat inside destination list 100 pool p2p
access-list 100 permit tcp any any range 6881 6999
Thanks for getting me on the right track!
Shane C.
