VPN Client has wrong Default gateway
Jun 3rd, 2008
The VPN Client connects to the 3015 Concentrator fine but for some reason this vendor is getting a default gateway of 10.10.0.1 when they should have an IP address of 10.10.0.47 (The IP address of the assigned to the client) The actual default gateway is 10.10.0.254. It is like the client is dynamically assigning the default gateway. It is a Windows 2003 server. Has anyone had a similiar issue? Statically assigning the default gateway did not fix problem. Other remote clients are not having any issues.
Thanks in advance.
a.alekseev Wed, 07/16/2008 - 04:56
  • Gold, 750 points or more
Hi, Gaurang.K. Pandya
What is your problem?
gaurang_pandya Wed, 07/16/2008 - 05:55
my RA pool is 172.16.100.1-172.16.100.254, my client is getting ip 172.16.100.1 assigned to it and the default gateway that he gets is 172.16.100.2 this is strange, as for vpn the gateway should be same as assigned ip address.
a.alekseev Wed, 07/16/2008 - 06:40
could you show "ipconfig /all"?
