How do I open a port on a router?
Jun 3rd, 2008
i need to open 4 ports on a router.
ports # 80, 443, 6464, and 7575.
i feel really dumb, but can someone help me out?
its for a IPSEC, LAN-2-LAN connection. THey can send information, but cant receive, and these ports are closed. They need to be open. HELP!
Dustin
JORGE RODRIGUEZ Wed, 06/04/2008 - 04:25
  • Green, 3000 points or more
Whichever you are terminating the tunnel at router or firewall the acl on the router or firewall terminating the tunnel will allow the traffic.
sdoremus33 Wed, 06/04/2008 - 09:21
  • Bronze, 100 points or more
One thing you can do is run a packet capture on your firewall( fw--> dst and reverse). If you are using PIX Ver 5.xx or 6.xx you can run the following command
(See Below)
capture -acl specify source traffic to destination including -interface to which the traffic is flowing.
Ex First create a test ACL to see if the ports are open or blocked from the firewall to dest
ACcess List 102 permit x.x.x.x where x.x.x.x = src to y.y.y.y where y.y.y.y is the destination and test all ports by using acl for each port to test
Then run capture -name, and run traffic to see results.
after you run traffic through
go back and type capture _name, this will give you the output, check to see if there are any resets denoted by -R in the trace, and if there are thats your problem. This means that the packets are being reste to src due to blobked port primarily on the FW. HTH
sdoremus33 Wed, 06/04/2008 - 16:56
Your best bet is through the ADSM gui interface
