3750G "show platfrom port-asic stats drop" showing some packet drop
Jun 3rd, 2008
#show platform port-asic stats drop
showing some packet drops, what is the implication of the result? Should I concerned anything? I did not clear the counter for two monthes.
Port-asic Port Drop Statistics - Summary
RxQueue 0 Drop Stats: 0
RxQueue 1 Drop Stats: 0
RxQueue 2 Drop Stats: 0
RxQueue 3 Drop Stats: 0
Port 0 TxQueue Drop Stats: 0
Port 1 TxQueue Drop Stats: 0
Port 2 TxQueue Drop Stats: 3298
Port 3 TxQueue Drop Stats: 0
Port 2 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
--More-- Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 3298
andrew.butterworth Tue, 06/03/2008 - 14:12
Should you be concerned? It depends....
Check what DSCP & CoS values map to threshold 3 of the 4th queue as that is the only one that has dropped any frames (show mls qos maps). I haven't got a 3560/3750 to hand so I don't know what this is by default, although I have a feeling by default nothing maps to the 3rd threshold of any queue.
3298 frames over two months doesn't sound a lot to me, however if the network is not loaded at any time then it is possible the queue thresholds/sizes need tuning.
Andy
Yogesh Singh Tue, 06/03/2008 - 20:47
Actually he should be concerned ...I am not a QOS expert but , a misconfigured QOS can cause asic level drops ... you may try to disable qos on all the interfaces that are using this asic .
After that please check if the drops are still incrementing or not .
If its not because of QOS then this is a hardware issue , asic limitation .
andrew.butterworth Wed, 06/04/2008 - 08:39
It may be the desired behaviour - i.e. congestion avoidance. The 3560/3750 uses congestion avoidance (random dropping) when thresholds are being reached in queues, this can be a desired behaviour to slow down flows if TCP traffic is mapped to that queue/threshold.
Andy
royalblues Wed, 06/04/2008 - 10:43
We had a similar issue due to a misconfigured QoS and had to tweak the thresholds to rectify it.
Check whether the counters are increasing as you cannot clear them without a reload.
Narayan
patoberli Mon, 01/16/2012 - 02:00
We don't have any QoS in use, but I see a high number of drops when the load increases to over 600Mbit/s on that interface. See:
show platform port-asic stats drop g1/0/26
  Interface Gi1/0/26 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 3529272
    Queue 4
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 5
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 6
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 7
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
And here the interface:
sh int g1/0/26
GigabitEthernet1/0/26 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0026.9981.e11a (bia 0026.9981.e11a)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 17/255, rxload 2/255
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:04, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:19:07
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 150
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 10629000 bits/sec, 6922 packets/sec
  5 minute output rate 67813000 bits/sec, 10457 packets/sec
     16633696 packets input, 2137400609 bytes, 0 no buffer
     Received 111580 broadcasts (56109 multicasts)
     0 watchdog, 56109 multicast, 0 pause input
     28212625 packets output, 35494347176 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
sh mls qos
  QoS is disabled globally
sh int g1/0/26
  Keepalive not set
sh mls qos
It's actually in a portchannel with a second interface, which doesn't show any errors.
Could that be a broken hardware?
It's a stack consisting of two WS-C3750E-24TD with software 12.2(58)SE1.
