NAT Issue
Jun 3rd, 2008
I'm hoping a NetPro can help me out. Hanging off my firewall (ASA 5520), I have an interface named "hosted". Off that segment there are two web servers: and Along with a few other servers. has an external IP address of 216.X.X.182. When any internal Users try to hit which, points to 216.X.X.182 via DNS, the firewall redirects the connection to via the Alias command. My issue comes whenver I try to access the server directly by it's IP address. I don't really understand why I can't access this server. The Log doesn't show any messages as to what's going on with this from what I can see. I flipped the Alias around so it would translate the DNS query (DNS Server sits in DMZ), but then I'm still not able to get to the IP directly. I changed it back so it would just redirect at this point. Our Management server is, and sits on the "Inside" of the network. This server has a translation to itself into that network for management of the servers there.
The Users that use these servers the most are at and are Nat-exempted. Everything was setup fine until we had to put the alias in to redirect the connection from the public IP to the private.
Here's the Relevant config:
static (hosted,outside) 216.X.X.182 netmask
alias (inside) 216.X.X.182
nat (inside) 0 access-list no-nat
nat (inside) 1
global (hosted) 1 netmask
static (inside,hosted) netmask
access-list no-nat line 1 extended permit ip
I did a packet capture on the hosted interface and see what I'd like to see:
1: 16:41:42.064495 802.1Q vlan#33 P0 > icmp: echo request
2: 16:41:42.064693 802.1Q vlan#33 P0 > icmp: echo reply
The server is responding, but the echo replies are not making back to my managment server. I did a capture on the "Inside" interface and found that the Echo Replys are being translated to the 216.X.X.182 IP. How can I keep this from happening?
So, to make a long story short:
I want the firewall to redirect internal requests to 216.X.X.182 to but I'd also like to be able to access directly.
Is this doable??
Thanks in advance.
JORGE RODRIGUEZ Tue, 06/03/2008 - 17:24
This is a perfect example for your scenario.
Look at hairpining and static nat entries section towards the end of this link.
We have similar scenario with public servers whereby when access directly from inside we make alias dns entry in our internal DNS servers to use the internal IP for given public dns so inside users can access public srvs internally with internal private IPs, however, I believe above link hairpining should resolve your request.
