Poor performance when saving documents to remote share
The following operations appear to be optimized by WAAS while on servers behind the datacenter core WAE:
1. Navigating through directories
2. Opening files
3. FTP
4. HTTP
5. Copying files from the server to the workstation and vice versa.
However, when saving the files it takes a long time since it writes the entire temp file to the share and this does not appear to be optimized.
In this scenario the datacenter core is using a WAE 612 while the branch office edge is using a WAE 502 mod. Both locations are configured to use WCCP redirection.
Has anyone experienced something similar?
Overall Rating: 5 (1 ratings)
dstolt Tue, 06/03/2008 - 17:04
  • Cisco Employee,
David,
Have you double checked your connectivity directives to ensure they correctly reflect the WAN link parameters? What is the speed and latency for your WAN link?
Each type of MS Office program reacts to temp files differently, however they all should be able to take advantage of CIFS + L4 optimizations.
Dan
dstolt Fri, 06/06/2008 - 18:46
  • Cisco Employee,
Out of curiosity, what is your hardware (edge and core) and the memory in the boxes?
Do you see the connection in "sh tfo con sum" or is it inside the 4050 tunnel? If it's inside the tunel, it's being optimized, just taking way longer then a simple copy which uses different CIFS commands. Is it worse without WAAS?
Dan
dstolt Tue, 06/10/2008 - 09:28
  • Cisco Employee,
Is the connection inside the tunnel or do you see a 139/445 connection for that client/server outside the tunnel?
You should see the connection under "sh cifs connection list"
Dan
dstolt Tue, 06/10/2008 - 19:34
  • Cisco Employee,
The only other think that I would have you check is your interfaces speeds and duplexs, however if your other application optmization are OK, you may not be able to do much more for the save operation which is contrained mostly by latency (reading from the temp file and completely replacing the original file).
Dan
