Need help with asa5510 access-list's
Answered Question
Jun 3rd, 2008
When I add an access list to allow a service group access through the firewall all traffic is blocked config posted below.
: Saved
: Written by enable_15 at 08:48:32.873 EST Tue Jun 3 2008
ASA Version 7.0(7)
hostname ciscoasa
domain-name my.asa.org
enable password xxxxxxx encrypted
names
no dns-guard
interface Ethernet0/0
nameif WAN
security-level 0
ip address 24.xxx.xxx.133 255.255.255.224
interface Ethernet0/1
nameif DMZ
security-level 50
ip address 10.100.100.1 255.255.255.0
interface Ethernet0/2
nameif LAN
security-level 100
ip address 192.168.100.232 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
passwd xxxxxxxxxxxx encrypted
ftp mode passive
clock timezone EST -5
object-group service internet tcp
port-object eq www
port-object eq domain
port-object eq https
port-object eq ftp
access-list LAN_access_in extended permit tcp 192.168.0.0 255.255.0.0 any object-group internet
pager lines 24
logging asdm informational
mtu management 1500
mtu LAN 1500
mtu DMZ 1500
mtu WAN 1500
asdm image disk0:/asdm-507.bin
no asdm history enable
arp timeout 14400
global (WAN) 10 interface
nat (LAN) 10 10.10.0.0 255.255.0.0
nat (LAN) 10 192.168.0.0 255.255.0.0
access-group LAN_access_in in interface LAN
route LAN 192.168.0.0 255.255.0.0 192.168.100.1 1
route LAN 10.10.0.0 255.255.0.0 192.168.100.1 1
route WAN 0.0.0.0 0.0.0.0 24.xxx.xxx.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.0.0 255.255.0.0 LAN
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 192.168.1.0 255.255.255.0 management
telnet 192.168.0.0 255.255.0.0 LAN
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:xxx
: end
Correct Answer by husycisco about 8 years 10 months ago
Hi Dennis,
"all traffic is blocked config posted below"
By default, traffic from a higher security level interface to lower security interface is permitted. You wont have to define any specific ACLs. Any ACLs defined to the higher security interface (LAN interface for your issue) makes filtering rather than secuirng.
In your issue, the LAN_access_in ACL permits the specified traffic and denies the rest by implicit deny. I see a NAT statement for 10.10.0.0 255.255.0.0 network, and a permit doesnt take place for that.
Now if the issue is "all internet traffic is blocked" or "cant access internet", the issue is you permit domain port (53) for a tcp object group. You also have to permit UDP port 53 for resolving names correctly.
Overall Rating: 5 (2 ratings)
Fernando_Meza Tue, 06/03/2008 - 15:50
  • Gold, 750 points or more
Make sure you are testing from the range 192.168.0.0 255.255.0.0. because this is the only range allowed by the ACL. Appart from that I can't see anything wrong on the configuration.
Correct Answer
husycisco Tue, 06/03/2008 - 17:00
Hi Dennis,
paulwhite1977 Thu, 06/05/2008 - 08:35
Its worth checking the scurity levels and the logs.
If the log reveals 'no translation group found for' it may be that like in the old pix you require a static translation in order to pass from the low level of security to the high.
You can in later revisions of PIX remove this with the no nat-control command
dcholl1 Thu, 06/05/2008 - 11:02
I would like to Thank everyone who replied to this message. I'am afraid the answer was very simple I did not add the udp domain port in my access list therfor I could not pull dns info. I am sorry not to have caught this myself but I am thankful for all the help.
Dennis
husycisco Thu, 06/05/2008 - 16:10
Dennis,
Glad your issue is resolved. Would you please rate my previous post which suggested you to permit UDP 53 for internet connectivity?
