Caller ID
Answered Question
Jun 3rd, 2008
Does anyone know where I change what number is reflected on call ID for outbound calls.
Correct Answer by thisisshanky about 8 years 12 months ago
Under the phone you can put an external phone number mask and then on route patterns you can check the option for sending External phone number mask. THis can also be done at route list level, to allow the external phone number mask to be passed out to PSTN. Please note that you would eitehr do this only at route pattern level or Route list level and not both.
Overall Rating: 5 (1 ratings)
Correct Answer
thisisshanky Tue, 06/03/2008 - 15:51
  • Purple, 4500 points or more
