Firmware upgradation on 7975 IP Phone
Jun 3rd, 2008
We are running UCM 5.1.3 cluster.
We are planning to upgrade the firmware 7975 IP Phones; my query is can i upgrade it on only one 7975 IP Phone so that i can verify the functionality of the upgraded 7975 IP Phone, if everything is fine then do it for all.
Please let me know the procedure to do it.
Help me out..
thisisshanky Tue, 06/03/2008 - 21:13
  • Purple, 4500 points or more
If you have installed the firmware file then you can specify the firmware file name specifically under one phone and reset the phone. This will ugprade the firmware on one phone and not all of them.
Sankar
PS: please remember to rate posts!
