PEAP - user authentication and mac authentication
Answered Question
Jun 4th, 2008
Can I use PEAP with Mac and user (login and password windows) authentication ?
Do I need CISCO ACS?
PEAP with user authentication and MAC filtering, Is this possible?
Correct Answer by Scott Fella about 9 years 1 month ago
You will have to do MAC Authentication on each ap. This would require you to enter all the allowed mac address on each ap. You will not be able to do PEAP without a radius server. You can always install MS IAS server if you are a MS shop. :)
Overall Rating: 5 (1 ratings)
Scott Fella Wed, 06/04/2008 - 02:44
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You can do PEAP with MAC Authentication on the WLC. It will be under local EAP. MAC Authentication is really not required, since it is so easy to spoof a MAC. Also with PEAP, they will have to authicate to the WLC DB or LDAP.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008093f1b9.shtml
lamanso Wed, 06/04/2008 - 03:44
Thanks Fella,
We have today an autonomous systems with 19 air-ap1131ag and 1 WLSEExpress.
We want do PEAP with user authentication and mac authentication.
Can I do this with this devices?
Can I do PEAP and mac filtering (centralized or configured each one?
Correct Answer
Scott Fella Wed, 06/04/2008 - 05:21
  • Hall of Fame,
    2017 Wireless
lamanso Wed, 06/04/2008 - 06:05
Thanks fella5
We are going to install a MS IAS server like Radius server for PEAP.
Scott Fella Wed, 06/04/2008 - 06:28
  • Hall of Fame,
    2017 Wireless
You will need to install a certificate also into your radius server. So you can bring up an MS certificate CA and generate one and you will be good to go.
drgebhardt Tue, 06/17/2008 - 12:09
Does anyone have PEAP/IAS config example for an autonomous AP (1242) ?
drgebhardt Wed, 06/18/2008 - 06:45
Thanks for the input. Any possibility that a the text based config from an autonomous AP is available? Or possibly the 1242 GUI screen shots?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
