IPCC microsoft components
Jun 4th, 2008
Hi All,
I have ordered IPCC components from cisco and evry thind is delivered properly but the question about windows server 2003 qnd SQL server , should i order them seperatly or should be delivered by cisco with IPCC software ???
Riccardo Bua Wed, 06/04/2008 - 01:46
  • Cisco Employee,
did you ordered MCS servers? Those will be shipped with the OS if you selected the right part number.
Riccardo
icabrera Wed, 06/04/2008 - 03:05
  • Silver, 250 points or more
Hi, take a look at the document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/icm_enterprise/icm_enterprise_7_0/user/guide/icm70bom.pdf
At "7.7 ICM/IPCC System Software Requirements" it's explained all about the licensing requeriments depending on your ipcc configuration.
Regards.
Hope this helps, if so pls rate post
