Question Ref: VPN Encryption
I have a question that's puzzeling me, I have the below setup on my PIX 515 running Version 6.3(5) - both of the below VPN tunnels are up.
My question is...
When I do show isakmp sa detail, I observe for my VPN tunnel that is using transform-set Y456 using encryption 3des and Hash MD5, shouldn't I see:
encryption = AES and Hash = SHA as per transform-set Y456?
Has any one seen this before or am I running into a bug?
crypto ipsec transform-set X123 esp-3des esp-md5-hmac
crypto ipsec transform-set Y456 esp-aes-192 esp-sha-hmac
crypto map MYMAP 1 ipsec-isakmp
crypto map MYMAP 1 match address 103
crypto map MYMAP 1 set peer 123.456.789.100
crypto map MYMAP 1 set transform-set X123
crypto map MYMAP 2 ipsec-isakmp
crypto map MYMAP 2 match address 104
crypto map MYMAP 2 set peer 111.222.333.444
crypto map MYMAP 2 set transform-set Y456
crypto map MYMAP interface outside
isakmp enable outside
isakmp key <KEY1234> address 123.456.789.100 netmask 255.255.255.255
isakmp key <KEY5678> address 111.222.333.444 netmask 255.255.255.255
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
isakmp policy 2 authentication pre-share
isakmp policy 2 encryption aes-192
isakmp policy 2 hash sha
isakmp policy 2 group 5
isakmp policy 2 lifetime 1440
EURO_FW01# sho isakmp sa det
Local Remote Encr Hash Auth State Lifetime
222.333.444.555:500 111.222.333.444:500 3des md5 psk QM_IDLE 86082
222.333.444.555:500 123.456.789.100:500 3des md5 psk QM_IDLE 9316
michael.leblanc Wed, 06/04/2008 - 06:03
You are confusing ISAKMP policy with IPSec policy.
The output of "show isakmp sa detail" is showing you the "ISAKMP" protection suite used for the bi-directional SA created during Phase 1.
Look at the "isakmp policy 1" parameters and you will see a match with the command output.
The transform-set you are referring to is the protection suite used for the two unidirectional IPSec SAs created during Phase II.
If you want to see the IPSec SA detail, you would likely use a command such as:
"show ipsec sa detail"
