LMS 2.6: /var/adm/CSCOpx/files/rme/dcma/difffiles directory too big
Answered Question
Jun 4th, 2008
Hi folks!
The difffiles directory, after purge the old config files, increase its size continuosly.
So, how I can reduce its size?
Leonardo
Correct Answer by Joe Clarke about 9 years 1 month ago
You are seeing CSCse88215. The workaround is to manually delete the contents of the difffiles directory. They will be recreated as needed.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 06/04/2008 - 07:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
