Warning message
move WCS (v5.0.56.2) from server to another
Jun 4th, 2008
I only found a conversation from 2005 which didn't end with a solution - maybe there is one in the meantime???
I made a backup of the old server, put this on the new one, reinitialized the database on the new, made a "successful" restore of the DB - BUT start WCS failed with these messages:
Starting WCS
ERROR: ld.so: object 'libblas.so.3' from LD_PRELOAD cannot be preloaded: ignored.
Cannot run with the current schema. Exiting.
Apache server is already stopped.
Failed to start WCS server.
Is there a way to to this?
Overall Rating: 5 (1 ratings)
Scott Fella Wed, 06/04/2008 - 15:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You might have to reinstall WCS.
FRANK SCHADE Thu, 06/05/2008 - 00:06
the same error after a reinstall:
Scott Fella Thu, 06/05/2008 - 04:32
  • Hall of Fame,
    2017 Wireless
After uninstaling and reinstalling does WCS services start. This is without doing a restore. If without doing a restore you have this error, then it might be due to the server requirements or the instll files. If this happens after you do a restore of the DB, then you have a bad restore file.
FRANK SCHADE Thu, 06/05/2008 - 06:08
after deinstallation and reinstallation WCS was runnnig;
I also used new backup file.
The restore was "successful" again - but this time I only get;
Starting WCS: [FAILED]
Do I have to provide the license before the restore?
Scott Fella Thu, 06/05/2008 - 06:13
  • Hall of Fame,
    2017 Wireless
You might want to install the license first and verify that gets added.
FRANK SCHADE Thu, 06/05/2008 - 06:31
I just tried this - now I have the error message which I found at the begining.
After reintializing the DB I could start WCS again. So probably it's a matter of the backupfile.
I created this just with "./dbadmin.sh backup backupfile". Do I have to use a certain option or command???
Scott Fella Thu, 06/05/2008 - 07:29
  • Hall of Fame,
    2017 Wireless
That it right..... again, it might be a bad backup file.
Scott Fella Fri, 06/06/2008 - 04:04
  • Hall of Fame,
    2017 Wireless
I don't know unless you actually try to restore the backup file on another WCS server. I would open a TAC case and see what they have to say.
Trending Topics - Security & Network
