Activatin AH in Cisco VPN Concentrator 3000
Answered Question
Jun 4th, 2008
I found a strange thing in our VPN concentrator 3000. Under IKe Proposal, I do not find if AH. Only ESP combination what I find. Any idea, how I would be able to activate that AH on my box?
Arabinda
Correct Answer by Farrukh Haroon about 8 years 11 months ago
No problem at all, you should push them to use ESP anyway (even in future) as AH does not offer encryption and is not NAT/PAT aware.
Its only useful for some special purposes now (I think IPV6 OSPF uses it for security purposes).
Please rate helpful posts.
Farrukh
Overall Rating: 5 (1 ratings)
Farrukh Haroon Tue, 06/10/2008 - 11:25
  • Red, 2250 points or more
Hey why do you want to use AH anyway, its lame :)
Anyway this is from Richard Deal's excellent book "The Complete Cisco VPN Configuration Guide"
"Please note that the concentrator doesn't support AH for L2L sessions, whereas the other VPN gateway products, like Cisco Routers, do." Pg 333
Farrukh
arabinda.sukla Tue, 06/10/2008 - 21:16
Hi Farrukh,
We are a offshore development center. Sometimes we need to use those IKE parameters which our client engineers want to. No worries time the client agreed to use ESP, so all set now.
Thank you for the valuable info.
Arabinda
Correct Answer
Farrukh Haroon Tue, 06/10/2008 - 23:27
Farrukh
