NAT over IPsec L2L with PIX
Jun 4th, 2008
I have the following challange and I can solve it partially only.
Scenario:
I need to connect two sites through ipsec L2L and apply some NAT back and forth.
The remote network is 10.1.0.0/24 my inside network is 192.168.1.0/24. The remote site cannot send traffic to 192.168.1.0 because this subnet is used on their network. So they are going to send the traffic to 10.10.1.1 for ftp and 10.10.1.2 for http. On my side I have 192.168.1.30 as ftp and 192.168.1.31 as http server. On my side when the traffic comes I have to translate the destination of 10.10.1.1 and 10.10.1.2 to 192.168.1.30 and 192.168.1.31 respectively.
I also have to send back some traffic to the remote site with source of 10.10.1.3 (from 192.168.1.30 and 192.168.1.31). So it means it is some kind of asymetric NAT. The question is whether it is possible or not? If possible how to approach it?
Krisztian
JORGE RODRIGUEZ Wed, 06/04/2008 - 13:50
Kristian,
You can apply the overlapping networks strategy in your scenario, you will need policy nat. I've created a draft script bu if I have the time I will tested, however, it should be along those lines, look at the example link.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808c9950.shtml
You could have these acls for your tunnel.
access-list new extended permit ip 10.10.1.1 255.255.255.255 10.1.0.0 255.255.255.0
access-list new extended permit ip 10.10.1.2 255.255.255.255 10.1.0.0 255.255.255.0
access-list policy-nat_FTP extended permit ip 192.168.1.30 255.255.255.255 10.1.0.0 255.255.255.0
access-list policy-nat_HTTP extended permit ip 192.168.1.31 255.255.255.255 10.1.0.0 255.255.255.0
static (inside,outside) 10.10.1.1 access-list policy-nat_FTP
static (inside,outside) 10.10.1.2 access-list policy-nat_HTTP
Rgds
-Jorge
kerek@banknet.net Wed, 06/04/2008 - 22:17
Hi Jorge,
Thank you for your reply. I have also found that link but it seems that scenario is working only in case of the traffic going from my side (let say this is PAX-A) to the remote however I need the opposite. It is mentioned that if there is traffic coming back to the translated address (in my case 10.10.1.1, and .2) it will not reach the inside network. Do you know any other way to achieve this?
Krisztian
