%CDP native vlna mismatch
Jun 4th, 2008
Hi all,
I have 2 catalyst (WS-C3560G-48TS and ME-3400-24TS) connected back-to-back via fastethernet. The 2 ports are configured in access on different vlan: vlan 3 on 3560 side and vlan 207 on 3400 side.
In my log I see a cdp mismatch of native vlan:
(log un 3400 side):
Jun 4 15:17:38.619: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/6 (207), with s3560-fiu1 GigabitEthernet0/48 (3)
Is it a normal behaviour?
Normally I have seen this kind of log on a trunk port if we change the native vlan only on one side..
Is it the same for an access port?
Many thanks in advance for your support
Pravin Phadte Wed, 06/04/2008 - 06:24
This is not a noramal behaviour since its a configuration problem with native vlan.
can you paste the configuration on the trunk interface for both the swithes conneted to each other.
or to troubleshoot you may follow as below.
1] show interfaces (name) trunk
in this output u will find which vlan it is been in.same command on the other trunk interface.
2] as per cisco if both the inteface have diffrent native vlan you will have to decide which native vlan you need to use. by default is is vlan1.
3] config t
int (name)
switchport trunk native vlan 2
4] I have come across same errors and providing the above command did not work.
not sure if it was ios problem.
you may need to add this commnad depending on your vlans on the switch.
config t
int (name)
switchport trunk allowed vlan 1,10,179-202,1002-1005
Hope this helps.
cannone78 Wed, 06/04/2008 - 06:50
Thanks for your support..
Normal behaviour was not referred to vlan mismatch itself but mismatch on an access port!
Here you are the conf of the 2 port:
interface FastEthernet0/6
description MAN
port-type nni
switchport access vlan 207
speed 100
spanning-tree bpduguard enable
spanning-tree guard root
interface GigabitEthernet0/48
switchport access vlan 3
switchport mode access
load-interval 30
mls qos trust ip-precedence
spanning-tree bpdufilter enable
no shutdown
As yuo can see the 2 ports are access port and no trunks.
Issue 'show int trunk' the above interface are not listed as trunk port.
Best regards
Pravin Phadte Wed, 06/04/2008 - 07:00
Hi cannone78,
Yes you will get the errors for the access port also. All the taged traffic will be moving from the trunk ports.
Do you have a trunk configured between these two swithes ?
If not are these swithes conneted to some other swith and running trunk link to these swithes ?
If both the swithes are conneted end to end who are faceing the error then you will have to check the vlans configured on the swith.
show int status
config t
int (name)
need to do this on both the swithes to get these errors away.
cannone78 Wed, 06/04/2008 - 07:09
I have no other port between the 2 switches.
I have other trunk port towards other switch with native vlan 1.
Anyway, if it's a normal behaviour to see a mismatch vlan also on access port...i'm obliged disabling cdp on that port.
Unfortunatly I can't configure the same vlan between them.
Best regards
Pravin Phadte Wed, 06/04/2008 - 07:17
As per my knowledge cisco says that this happens only when there is a native vlan mistatch.
i have seen these errors on many swithes and dint not find problems most of the time.
There was once a problem which i faced with these errors when the cpu utilization of the swithes turned on to be high and after adding the vlans they were normal.
I gues there should be no problem if its not effcting any network.
I would also suggest to wait for more resopnce on this.
Edison Ortiz Thu, 06/05/2008 - 10:05
CDP will complain on the mismatch (normal behavior) but traffic should flow as expected.
If the error message bothers you enough, you can disable CDP.
Ryan Carretta Thu, 06/05/2008 - 10:43
You should fix this unless it's an intended configuration and you know what you're doing mismatching vlans. The error message is there for a reason. It's not a good fix to just disable CDP to stop the message from getting printed.
CDP is complaining because you are potentially bridging two vlans together into a single broadcast domain. For example, if you transmit an untagged broadcast in vlan 5, and the directly connected switch receives that packet in vlan 10, it will flood the packet in vlan 10. If there are two points of bridging between vlans, you will create a spanning-tree loop, since vlans 5 and 10 will not participate in STP with one another.
cannone78 Thu, 06/05/2008 - 23:56
Thabks a lot for your support.
no problem about spanning-tree since as you can see in my configuration I have filtered bpdu on both switch (I've also configured bpduguard..). I can't use the same vlan since on 3400 side the vlan is a VLAN of a MAN network of a service provider; on 3750 is a customer VLAN that can't be changed.
