FWSM Memory Management Ver 3.1(5)
Jun 4th, 2008
We have a FWSM running ver 3.1(5). We are running into memory problems on one of the contexts/partitions. Apart from using the
resource acl-partition <number-of-partitions>
command, is there any way of manually reconfiguring more memory to the particular context which requires the most?
Is there a good webpage with memory management advice for the FWSM?
Senan
3ssheedy Fri, 06/06/2008 - 02:08
Thanks Farrukh
The context is already in its own memory partition but I'll configure it exclusive now as well.
Senan
Farrukh Haroon Fri, 06/06/2008 - 02:32
I'm sorry this is the only alternate I know of. If you add multiple contexts then they start sharing the partitions. This way you can at least guarantee one partition for this high utilization context.
Farrukh
