Unity as an AA
Jun 4th, 2008
I am trying to set up our Unity (4.1) to function as an Auto Attendant. I only need this as a temp solution while I upgrade our IPCC cluster.
What is the best way to setup Unity to function as an AA? My thought was to use a Call Handler.
Thanks in advance.
Trae
thisisshanky Wed, 06/04/2008 - 08:28
  • Purple, 4500 points or more
Simply copy the default directory handler and create a new one, and assign a number to it. To reach the directory handler from callmanager, create a cti route point with the same DN as the directory handler and then call forward ALL the CTI route point to voicemail.
