Boot Error
Jun 4th, 2008
Does anyone know what would cause this error?
Equipment is Cisco Wireless Controller 4402
Error:
Basic type or enum can not be nested, error in the tool for h2
Basic type or enum can not be nested, error in the tool for XML_crc_file_size
Value = 481 for XML tag L2-Roam-Configuration is out of range
osapiTaskSaveStack: locking reaper_sleeper by sshpmReceiveTask, rc=0
osapiTaskSaveStack: locking reaper_sleeper by fp_main_task, rc=0
osapiTaskSaveStack: locking reaper_sleeper by DHCP Client Task, rc=0
DPCH - Discarded Packet Counter High = 0x0
DPCL - Discarded Packet Counter Low = 0x0
IPCH - Invalid Packet Counter High = 0x0
IPCL - Invalid Packet Counter Low = 0x0
BPCH - Bad Packet Counter High = 0x0
BPCL - Bad Packet Counter Low = 0x0
CTOS - Cell Top of Stack = 0x2c5
CBOS - Cell Bottom of Stack = 0x2c4
CDCNT - Cell Descriptors Counter = 0xffc
CDLMT - Cell Descriptors Limit = 0x200
ISID - Invalid Stream ID = 0x0
CHTF - Credit High Threshold (Fast Ethernet Ports) = 0xfff
CLTF - Credit Low Threshold (Fast Ethernet Ports) = 0x0
CHTG - Credit High Threshold (Gigabit Ethernet Ports) = 0x320
CLTG - Credit Low Threshold (Gigabit Ethernet Ports) = 0x0
CHTS - Credit High Threshold (Stack Port) = 0x320
CLTS - Credit Low Threshold (Stack Port) = 0x0
FGCR - Fabric General Control Register = 0xc30
ISPN - Invalid Stream Port = 0x0
* Start Cisco Crash Handler *
Sys Name: SihleWireless
Model:
Version: 5.0.148.0
Timestamp: Wed Jun 4 14:36:15 2008
signal: 11
pid: 758
TID: 16386
Task Name: fp_main_task
Reason: System Crash
si_signo: 11
si_errno: 0
si_code: 1
si_addr: 0x9421ffe4
timer tcb: 0x1
timer cb: 0x102cb068 ('asSigV1PrintSig+1000')
timer arg1: 0x0
timer arg2: 0x0
Analysis of Failure:
Software Failed on instruction located at: 0x0 (Unknown)
This signal was generated in response to a software
attempt to decode address: 0x8000
This error caused trap number 0x7f7f7f7f to be generated.
System Stack
Frame 0: 0x100066b4: create_crash_dump+1100
Frame 1: 0x10006488: create_crash_dump+544
Frame 2: 0x100014f0: sigsegv_handler+984
Frame 3: 0x10c0a8c8: __pthread_sighandler_rt+212
Frame 4: 0x301c2c88: ber_int_sb_write+525924376
Frame 5: 0x00000000: Unknown
Frame 6: 0x10d2024c: ber_int_sb_write+970204
Frame 7: 0x1037f398: xml_check_for_XML_root_tag+676
Frame 8: 0x10
Bootloader 4.2.112.0 (Mar 12 2008 - 19:38:43)
Motorola PowerPC ProcessorID=00000000 Rev. PVR=80200020
CPU: 833 MHz
CCB: 333 MHz
DDR: 166 MHz
LBC: 41 MHz
Scott Fella Wed, 06/04/2008 - 16:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Don't know, but it looks like a good time to open a TAC case.
