Different rings on different lines
Jun 4th, 2008
I am setting up a users phone and would like to have distinctive rings on 3 seperate lines. The problem I am having is that for each line I want to be able to select from the full ring tone list. The only options I have are Ring 1, Ring 2, etc. Can I somehow change the tones for Ring 1, 2, etc?
Chris Deren Wed, 06/04/2008 - 07:07
You need to modify the DistinctiveRingList.xml file with the same ring types as the RingList.xml.
Depending on CM version this procedure is differnt, but I am sure that if you search the list for this topic you'll find a ton of posts.
