serching by department in corporate directory at CUCM 4.x
Jun 4th, 2008
hi,
at a Cisco IP Phone there's a corporate directory, where the users can search for another users or phones in the CUCM. This is activated by typing an URL to /path to./CCMCIP/xmldirectory.asp.
You can search by lastname, firstname and phone number but not by department. Anybody knows how the asp-Files must be edited that searching by department is possible?
Where at the server can I found the object definition, that is called like this:
var userSearchTable = new ActiveXObject("UMX.UMHashTableX");
irisrios Tue, 06/10/2008 - 06:25
  • Silver, 250 points or more
There are no options to edit how the corporate directory functions. If you want to add functionality to the Directory, you will need to develop your own XML directory or purchase a third party solution. Or you can use "departmentnumber" to search directory by the way, xmldirectorylist.asp is using "firstname", "lastname", "telephonenumber" and "userid" to search the directory.
