6506 upgrade issues
Jun 4th, 2008
I've just upgraded my 6506 Supervisor engine (WS-SUP32-GE-3B) to s3223-ipservicesk9_wan-vz.122-18.sxf12.bin. After the initial start I try to do a wr or copy run start and I get a message that the system can not find the start-up config. Has anyone run into this? And how do I get this system back to normal?
Edison Ortiz Thu, 06/05/2008 - 10:02
  • Hall of Fame,
    Founding Member
Please post the show version output.
__
Edison.
edwin.thompson Sun, 06/08/2008 - 23:59
Thanks for your help. I got it working , I erased NVRAM and restarted the switch and it recreated the file.
Ryan Carretta Thu, 06/05/2008 - 10:47
  • Bronze, 100 points or more
Where are you saving your startup config? This can happen if you, for example, tell the switch to boot from a config file on a flash disk and then the disk is removed.
Try using 'default boot config' and then a write mem...it would be advisable to back up the config first.
Rajat Chauhan Thu, 06/05/2008 - 10:51
  • Cisco Employee,
Hi Edwin,
Please paste exact message along with "sh boot"
Raj
edwin.thompson Mon, 06/09/2008 - 00:00
