3750 AAA login
What would be reason for failure in loggin on to 3750 using AAA . The show log outpput is,
18w1d: %TAC-4-SERVREF: Warning: Server 10.80.132.12:0 is still referenced by server group
18w1d: %TAC-4-SERVREF: Warning: Server 10.80.132.23:0 is still referenced by server group
18w1d: %SYS-5-CONFIG_I: Configured from console by cisco on vty3 (10.32.68.120)
Richard Burts Wed, 06/04/2008 - 18:42
Aksher
The messages that you post are not particularly informative and do not seem to be related directly to the success or failure to login.
I would interpret the first two messages to indicate that two TACACS servers had been deleted from the config but that there is still a TACACS server group configuration that references these servers. And the third message is quite clear that someone had telnetted to the device and has made configuration changes (including the removal of the TACACS server definitions).
If there is still a TACACS server group referenced by the aaa authentication commands but the servers referenced in the server group are missing then I can believe that this would cause login via TACACS to fail.
If this does not explain the issue then perhaps you can provide a bit more detail about what is going on?
Rick
