Unity CUCM directory numbers
Answered Question
Jun 4th, 2008
Hi we have a failover system, does the directory numbers between primary and failover have to be consecutive, i.e. 7000-7071 for primary then can we have 8000-8071 for secondary or does the secondary have to start from 8072?
Also does the pilot number have to be consecutive from the ranges eg if i'm using 7000-7071 as the DN's can my pilot be 7999 for example or does it have to be 6999...cheers, J
Correct Answer by Rob Huffman about 9 years 3 weeks ago
Hi Jag,
Just to add a note here to the great tips from my friend Sankar (+5 for this Shanky!) Most people use a nice (easy to remember) DID number like you were thinking (7999) for the Unity Pilot Number. All the other DN's can be Internal (Non-DID) numbers, so you can save a little money. Only the Pilot number needs to be dialable from the PSTN.
Hope this helps!
Rob
Correct Answer by thisisshanky about 9 years 3 weeks ago
They dont have to be consecutive. The ports will be added to a line group and then each set of line group (primary and failover) will be added to a hunt list and then the hunt pilot inturn points to the hunt list. So all you have to make sure is that the line group for the primary server is at the top.
Also there is no limit to what number you can use for your pilot number as well. As long as all numbers are unique, thats all matters.
Sankar
PS: please remember to rate posts!
Overall Rating: 5 (4 ratings)
Correct Answer
thisisshanky Wed, 06/04/2008 - 08:25
  • Purple, 4500 points or more
Sankar
Correct Answer
Rob Huffman Wed, 06/04/2008 - 08:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jag,
Hope this helps!
Rob
askq2forum Wed, 06/04/2008 - 13:41
Your top guys, thanks for your response. Done this so many times but never gave it thought until I was asked the question..cheers again,J
Rob Huffman Wed, 06/04/2008 - 17:04
  • Hall of Fame,
    Founding Member
Hi Jag,
You are always welcome :)
Cheers to you as well!
Rob
thisisshanky Wed, 06/04/2008 - 17:56
Rob,
Thanks for the +5. Here is a 5 for the excellent recommendation of using non DID numbers.
