Per-VLAN Spanning Tree Protocol vs Rapid Per-VLAN Spanning Tree Protocol
Jun 4th, 2008
I have two Catalyst 6503 SUP2/MSFC2 (6503-A and 6503-B) connected with a Layer2 trunk. Both switches run Per-VLAN Spanning Tree Protocol. I have to change the STP protocol only on 6503-A and move to Rapid Per-VLAN Spanning Tree Protocol.
How does 6503-A behave in terms of Spanning-Tree on the trunk to 6503-B?
Is the interoperability between switches preserved?
Best regards
Stefano
Jon Marshall Wed, 06/04/2008 - 09:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Stefano
Yes the 2 will work fine together. Be aware that STP on any vlans that run across the trunk will default to standard 802.1d timers as opposed to the Rapid-pvst timers.
Jon
