Add Port to h323 Dial-peer
Jun 4th, 2008
Trying to add a new bri port to an existing h323 gw, which has 2 bri's already configured. When creating dial peer, I cannot select new bri port. do I need to reset the h323 in order to see the new port in dialpeer config? thanks
Chris Deren Wed, 06/04/2008 - 08:59
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
First of all is the card even detected? Does it show under "sh diag", second of all is there a voice-port in the configuration?
Chris
balitewiczp Wed, 06/04/2008 - 09:04
Shows up under show diag, and sho run.
voice port config is missing, cannot add 0/0/0
interface BRI0/0/0
no ip address
encapsulation hdlc
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
balitewiczp Wed, 06/04/2008 - 11:31
that looks like a global command. 2 BRI ports are already working. Is this an interface command? Also, tried removing the hdlc encap, keeps coming back.
