06-04-2008 08:37 AM - edited 03-15-2019 11:03 AM
I was going to install the Updates Wizard file but it tells me that the hardware is not supported by Cisco. The hardware is approved Cisco, but perhaps the updates file doesn't support the current CM version along with the hardware platform.
I'm running CM 4.1(3).
06-04-2008 08:44 AM
what update wizard?? i know of an update wizard for unity but no for CCM
javalenc
if this helps, please rate
06-10-2008 12:31 PM
the files to update the patches in CCM. Never mind, do you know of a way? when i change the time on the OS it doesn't change it on the phones.
06-10-2008 04:23 PM
there are several causes for that, CUCM not being DST compliant, not having the right date/time group, 3rd G phones without the DST load, OS not being DST patched
javalenc
06-12-2008 05:41 AM
Hello javalenc,
Stumbled across this post....where HAS the Unity update wizard download moved to???? I can't find it anywhere.
Jason
06-12-2008 07:00 AM
hopefully the link won't break:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=2.0(9)&mdfid=280391779&sftType=Microsoft%20Updates%20for%20Cisco%20Unity/Unity%20Connection&optPlat=null&nodecount=2&edesignator=null&modelName=Cisco%20Unity%20Version%204.2&treeMdfId=278875240&treeName=Voice%20and%20Unified%20Communications&modifmdfid=null&imname=null&hybrid=Y&imst=N&lr=Y
if it breaks, go to the SW page and follow this path:
Voice and Unified Communications > Cisco Unity Version 4.2 > Microsoft Updates for Cisco Unity/Unity Connection > 2.0(9)
javalenc
06-12-2008 07:12 AM
UGH!! Thank you!! My old link sent me to the new menu and I was stopping at 'Cisco Unity' assuming it would be listed there.
Thanks for the prompt response!!
Jason
