Import Route Pattern or Translation Pattern
Jun 4th, 2008
Hi.
I need import 150 route pattern or 150 translatio pattern to ccm 5.1. In Bat I don't see template to it. Are there same mode to import route pattern?
thanks
Overall Rating: 3 (1 ratings)
Chris Deren Wed, 06/04/2008 - 08:53
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
There is no bulk import of these. The only way you can accomplish this is if you create a tool that will utilize AXL, I suggest you post your question on the developer forum.
Sorry, HTH
Chris
