How to subscribe extension mobility in UDP by using BAT in CCM 6.0
Jun 4th, 2008
I'm not able to subscribe extension mobility service in UDP by using BAT in CCM 6.0. I already made a template and subscribed EM to it but it took effect only in first UDP rest doesn't acquire any change.
Is there any bug in CCM 6.0 ??
Also, would like to know if there is any option in BAT to update UDP.
richb1971 Tue, 10/14/2008 - 08:25
I'm having same problem. How did you get on? I can't seem to use BAT to add UDP's with EM configured on the UDP.
Rich
tafari.lima Wed, 06/24/2009 - 06:03
I do that using the following procedure:
1 - Export UDP all detais
2 - Change the necessary fields
3 - Import again to CCM, use the BAT option Updade UDP CSV File
4 - Use Insert User Device Profiles Configuration option
5 - Select the file and runs is
If help please rete
