Disable Aggressive Mode on a PIX running 6.3
Answered Question
Jun 4th, 2008
How can I turn off Aggressive mode on a PIX 501 running 6.3?
This is a security issue for our PCI compliance.
Correct Answer by Syed Iftekhar Ahmed about 8 years 8 months ago
You cannot disable aggressive mode in 6.3 code. PIX would try to initiate the connection first on Main mode and if it fails would try
aggressive mode.
Syed Iftekhar Ahmed
Overall Rating: 5 (2 ratings)
Correct Answer
Syed Iftekhar Ahmed Wed, 06/04/2008 - 11:12
aggressive mode.
Syed Iftekhar Ahmed
john.wittenberg Wed, 06/04/2008 - 11:19
Thank you for this information. I was afraid of that. Again thank you for your reply
John
grobinson23 Thu, 11/13/2008 - 08:25
In what version of the code can the disabling of aggressive mode be done?
Thanks!
