which router model ?
Jun 4th, 2008
hi all,
attached with diagram
our 12000 series core router has 101 mbps link trminated to it.since its a core box there is a plan to new router as mentioned in diagram
my question is which router model suits
following requirements
with this new router 4 gre tunnels will be established
should be supporting 101 mbps traffic load passing by.
any helps pls.
rgds/shiva
Overall Rating: 2.5 (2 ratings)
didyap Tue, 06/10/2008 - 10:56
  • Silver, 250 points or more
For that purpose you can use the 2600 series and also can use 1800 series router.
Collin Clark Tue, 06/10/2008 - 11:06
  • Purple, 4500 points or more
The 3825 router will support your connections (the copper gig and the SM fiber) on the chassis. You will need to purchase the SM fiber SFP though. If you will be running any services on the router (ie QoS) you might want to look into the 3845 or the 7200 series router.
If you're not goingto be running any services, you might be able to go to a lower platform such as the 2821 or the 2851 which have gigabit on the chassis and they support the Gigabit Ethernet High-Speed WAN Interface Card for your fiber connection.
Gigabit Ethernet High-Speed WIC
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016be8d.html
2800 series model comparison
http://www.cisco.com/en/US/products/ps5854/prod_models_comparison.html
3800 series model comparison
http://www.cisco.com/en/US/products/ps5855/prod_models_comparison.html
The 2600 nor the 1800 support gigabit interfaces, so they won't work in your design.
Hope this helps.
