Call disconnects everytime after 10 minutes
Rob Huffman Wed, 06/04/2008 - 11:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Joel,
Is this all calls Incoming and Outgoing? If this is CCM you could check;
Maximum Call Duration Timer (number of minutes)
CCMAdmin > Service > Service Parameter > Cisco CallManager > Advanced >Clusterwide Parameters (Feature - General)
The default for this setting is 720 minutes. Perhaps this has been changed.
Hope this helps!
Rob
a.gooding Fri, 06/06/2008 - 19:45
  • Bronze, 100 points or more
is it an MGCP gateway? if so have you done the no mgcp timer command?
