Sniff a packet more than 1500 bytes on a switch
Jun 4th, 2008
Is it possible? If yes, could you suggest a software and the settings?
Prakash
prakashj Thu, 06/05/2008 - 21:48
Thanks Edison....
The mtu is already higher than 1500...and I am using wireshark...but still do not get any larger packet in the sniffer...
Prakash
Edison Ortiz Fri, 06/06/2008 - 05:10
If your devices (switches and workstation NIC) support Jumbo frames *and* they are enabled, then I don't know what else to tell you.
Perhaps asking in the wireshark forum should be the next step.
___
Edison.
